manzaboy 0
Hi, Thanks in advance as I am a Fibaro newbie.
I am looking at my kitchen plinth lighting and have a few questions.
The kitchen has 3 zones; an L-shaped stretch, an island and a single bank of units.
All are wired individually and go back to a single switch.
So I need to get 3 sets of LED strip lighting for the plinths to go across each area and speaking to my electrician I need 3 drivers for each LED strip.
A few questions;
1) My understanding is that as the Fibaro RGBW unit goes between the driver and the LED strip I will also need 3 fibaro modules?
2) If I want to just install white LED rather than coloured could I use single retractive switch with a Fibaro Dimmer 2 and dim the white or would that not work because I will be dimming the power to the 12v driver?
Any advice from anyone who has done something similar would be appreciated.
Cheers
Manzaboy
