Wall plug - WIFI not compatible - cannot add device
I get an error message that my WIFI is not compatible. Must I do something?
I don't have Apple TV. Maybe that's the problem?
12 answers to this question
    Anybody? :|
    @Estebano21 try a lower channel, try 3,8 or 11
    Hi
    You get this message from fibaro in the brouwser interface
    @Jaapkooi Sorry. I don't understand. Can you access also through a webbrowser?
    Some more information
    - When using the fibaro app it gives an error without any information
    - When using the Apple Home App it says: your device is not compatible with your WIFI router.
    I have changed the channels on the WIFI, no results :-(
    @Estebano21 use 2.4GHz n type network
    I did use 2.4
    33 minutes ago, Estebano21 said:
    I did use 2.4
    And is it N type Wi-Fi?
    I suppose it is an N type. See screenshot
    802.11gn
    Edited by Estebano21
    I have put my WIFI router to 802.11g
    No result :-( I don't know what to do further.
    802.11gn
    Hi
    What ar you trying to pair to the fibaro.
    I don't understand that it brings up wifi you are pairing a z-wave divice
    z-wave device?
    My device is an Apple Homekit device. So, WIFI is logical, no?
    46 minutes ago, Estebano21 said:
    z-wave device?
    aha
    Now i see.
    I know that some device's have troble with @ or % marks in te passwords have you tried a simple password for your network (for test) just WEP with password 1234567890
    edit   What do you use as server for the Apple Homekit if joun dont have a apple tv
    Edited by Jaapkooi
