Set end date/time on Holiday Mode in heating panel
Guest fja
Have tried to do some programming, but really beyond me.. What I ideally want would be a easy way to changes schedules for a heating zone - to allow for higher daytime temperature when at home for holiday a.o
Second best would be a workaound using the 'holiday mode'. Here I can actually also set higher temperature - as well as set i lower (which is clearly the intention). But to really be of use, I need to be able to set a end day/time as I always forget to reset settings.
This would also be ideal when on travel - allow automated resume of regular schedule, to ensure house is heated when getting home.
As you can understand we only use app very seldom, so it's not routine to go in and change / reset - that is why a end day/time would make things a lot easier.
Hope this can be added.
BR Frank
It can be done over the LUA and virtual device using manual mode. I have a simple VD with possibility with one click to enable manual mode for pre-selected time (in my case 15-30-60 minutes).
/monthly_2018_11/aa.JPG.c2ecc31f4b6ff8f6b817e1a482480bf6.JPG" alt="aa.JPG.c2ecc31f4b6ff8f6b817e1a482480bf6.JPG" />
