Hello, When I click on configuration - location I am not getting a proper icon below change location. Anyways when I click it map comes with message Google - This page can't load Google Maps correctly. When I enter a location in the search location box and click on next it says Configuration completed. When I click on finish and when I view the temperature it is not showing the correct current temperature of the location. As a result scene based on weather is not working properly. Please check and revert.
4 answers to this question
Guest fayelund
same here
Same topic here...
And if you could, there is no weather plug-in that is working using the location anyway.
The weather at my cabin is now -12 c. My scripting to keep it from freezing is useless when Yahoo AND Yr are showing + 8 ish all the time.
