OlaDola 1
I have tried for several weeks to get the Philips Hue plugin for HC2 to work stabile, but after anywhere from 5 minutes to 3 days after configuring it, it gives error message "Connection Timeout Error" and stops working. I then have to delete and re-add/configure the plugin to make it work again. It works fine for the 5 minutes to 3 days before it goes into connection timeout error.
I have tried static IP-address on Homebridge, rebooting everything, updating HC2, and even changing Zigbee channels (which is probably not the problem as it seems to be between HC2 and the Hue bridge).
Anyone have any solution for this?
5 answers to this question
