Help with a simple lights on by motion at night
Evening all.
I have had a HC2 now for a while and always used blocky scenes. You could say i have been living the blocky life for the last 5+ years!
I am starting to get frustrated with the lights/rgbw's going off and staying off when there is a lots of movement in the room. I have been advised that LUA is the way forward and will be able to get round this issue.
So the way i currently work my scenes for auto lights depending solely of motion and time of day is per the attached screen shots.
Can anyone help me out with a script that i could user per room to accomplish this?
I have found a script to turn the lights on when motion is detected and every time motion is detected, the timer will reset (and work 90% of the time) but if i use this script, the lights would be coming on during daylight and i do not want this. I just want them to come on when the time is past sunset and before sunrise.
Every room of my house has a Fibaro motion sensor and Fibaro RGBW or dimmer modal installed and would love this to work properly.
If anyone could help me out, that would be ace!
Thanks,
Hal
I had a similar ask last year. take a look at this. you will have to modify the code but it works really well for me.
    Thanks for the reply amatt.
    I have been playing with the code and learned a fair bit on the way but got my lights auto turning on when motion is detected and when the global variable Auto_Lights = Night. :D
    All is working ok and will continue to test tomorrow when there is a lot more movement around the house.
    I did see the following in the code but could not work out what it was for: -
    local function inArray(needle, haystack)
        for i,n in ipairs(haystack) do
            if (tonumber(needle)==tonumber(n)) then
                return true;
    Also, as I have only one sensor in the kitchen, I have listed it twice as it was needed for the script. When I have some time tomorrow, I will go through it to see if I can reduce it down to 1 sensor in the script without using the average lux.
    Thanks again for the reply and will chat again sometime soon:-)
    All the best,
    Hal
    Edited by Hallamnet
