Hi, i’ve installed a Finder Multifunction dimmer that controls 1 lamp from 3 switch; it has 3 connection like in picture, can i replace it with a fibaro switch? In positive case, can you tell me the right connection?
thanks
Hello
I would have a look at the Fibaro website. They have product manuals that you can download. Those manuals also have wiring diagrams. They are super useful.
Try this link
Ian
    1 hour ago, ianakapilotlight said:
    Hello
    Try this link
    Ian
    Wow! What a brillant answer!
    have you even think about a forum like a place where expert people could help unskilled people to understand how something works?
    i just read the manuals but i’vent understand if this fibaro switch integrate a dimmer or if there a possibility to install it togheter;
    thanks
    Hi @Petrinho,
    Do you have N wire (Neutral) in installation box? Without N you cannot replace it. Only Dimmers do not require N wire. Switches does.
    Jakub
    i can use the N wire without any problem because the dimmer is inside a box with other wires; my question is, replacing the dimmer with the fibaro switch, can i keep the dimmer function? (Now, more then i press the switch and more the light increase/decrease)
    thanks
    • 1 month later...
    No, You can't.
    This switch can only on/off. When You replace dimmer with the fibaro switch you will lost dimmer function.
    Edited by tking
