Looking for zwave sensor to monitor water flow
I am not successful to find any zwave sensor to measure water volume in pipe....
i only found water water valve to on/off water in pipe.
Please advise.
10 answers to this question
it two times save my 1st floor
Edited by 10der
@10der, I think he means a "flow" sensor (measunring throughput and usage) , not a "flood" sensor...
never saw.
but if he is developer he can use
0) any Water Meter Pulse Sensor with pulse output
1) Z-UNO connected to the Water Meter Pulse Sensor output
yes, Z-Uno is a high-ticket item you may use ESP8266 (~$2) and send pulse ticks to HC2, or vice versa poll ESP from HC2
Edited by 10der
    11 minutes ago, 10der said:
    never saw.
    Yes I mean water flow measure.
    By the way can you elaborate further on Water Meter Pulse?. Did it send pulse signal to nearby when unit count change? Over wire or wireless.
    wired
    for example
    /monthly_2018_12/image.png.185785c4ee2df12242d4f059c89f38ba.png" alt="image.png.185785c4ee2df12242d4f059c89f38ba.png" />
    7 minutes ago, 10der said:
    wired
    for example
     And should I wire this one into U-No shield as stated here -
    for example
    1) it's not zuno
    2) here you can find how to work with ZUNO + pulse event. In this sample counting of rain
    35 minutes ago, 10der said:
    for example
    1) it's not zuno
    Thanks 10der!. I got the concept. My next question is, let's say we can convert pulse to counter. How can we get it displayed in Fibaro GUI?. How does it look like then?
    Idk ;)
    if you develop it via ZUNO idk how HC2 can count it and show in HC2 UI
    maybe it will show as like a rain meter. It’s not bad as for me. But it’s my guess.
    if you develop it via ESP,
    1) poll device for grabbing values
    2) you should store count values in local database.
    (Cuz you want to know how many times your wife take a bath at this week ;), for example)
    3) you want to see this value in HC2. It’s simple VD
    Edited by 10der
    On 10. 12. 2018 at 14:47, Sita said:
    Vďaka 10der !. Dostal som ten koncept. Moja ďalšia otázka je, povedzme, že môžeme prevádzať impulz na počítadlo. Ako to môžeme zobraziť v grafickom rozhraní Fibaro ?. Ako to potom vyzerá?
    Hallo. Has anyone managed this to integrate into the FIBARO HC2?
