Time based scene.
I tried to find some answers to my question in this forum but I can’t find it.
i got a light sensor which is controlling my lights when it gets dark. This is controlled by a scene I guess u can not associate directly ?
this scene should be only active between 06 am to 10 pm. But I see that changes after this time or before still affect the lights.
i see that Fibaro don’t got a function only for a time period. So I used Intervall scene but is that right ? I don’t want Intervall only that the scene should be active in a specific time period.
can u create a scene with several then condition ? Like to merge 2 scenes by turning off and on? Might be only with lua coding?
@Alex Rob create a variable active (or another name) with on and off
scene 1
if it's 6 am then variable active = on
scene 2
if it's 10 pm variable active off
scene 3 (light scene)
if varaible active = on
and
pir lux = etc
then\etc
    I will try thanks a lot :)
    I reconized that some of the lights turns on after a while after i turn them off by a scene.
    I have nowehre programmed that they shall turn on again before the lux values are not reached.
    I have a scene that turns of 2 of 3 outside lights at 22:30 then i got 4 scenes for turning outside lights on and off / 2 of them are variabel scene for get a time period.
    Outside lights should be turned only on and off when lux is under 18 for on and above 22 for off.
    there is no way to get a traffic log? to see what is turning the lights on again? if its a scene or something else?
