How to trigger a scene in double switch 2 by held down in lua? FGS-223
Hello
Please help me.
I want to make a scene:
If i hold down S1 then S2 activaiting and then when i click once S1 then S1 and S2 turns off.
parameter 28 key hold down and key released is activated.
I have momentary switch.
S1 id is 312 and S2 id is 313
That lua not working:
%% properties
199 sceneActivation
%% weather
%% events
%% globals
local pressSource = fibaro:getSourceTrigger();
if
 (tostring(pressSource["keyAttribute"]) == "HeldDown")
then
    fibaro:call(313, "turnOn");
if
   fibaro:call(313 , "TurnOff")
15 answers to this question
First of all is the scene activated? and you probably get an error right?
You need to fix the code... you have two IF but one END.
Since S1 is 312 and S2 is 313... what device is 199?
FGS-223 doesn't do "sceneActivation" but instead uses the newer Central Scene Event. Z-Wave has 3 types of "scene" control ("scene controller", "scene activation", "central scene")...
See if you can make this work. Please edit the header, use first slave for "CentralSceneEvent" ID (not master, not switch itself.) - this was important  1 year ago, I am not sure if this is necessary on recent HC firmware versions. I cannot test right now.
    Like  this i get debug:
    unexpected symbol near 313
    What im missing?
    %% properties
    %% events
    312 CentralSceneEvent
    %% globals
    local trigger = fibaro:getSourceTrigger()
    if (trigger.type == "other") then
      fibaro:debug("Scene started by clicking 'start' button")
    else
      local pressSource = fibaro:getSourceTrigger().event.data
      fibaro:debug("CentralSceneEvent received from key: "..pressSource.keyId)
      if pressSource.keyAttribute == "HeldDown" then
        fibaro:debug("HeldDown") 313
      else
        fibaro:debug("Unknown CentralSceneEvent:"..pressSource.keyAttribute)
    Exactly what it says: That: "313" does not belong there, in the middle of your scene... What are you trying to do?
    I want to make like this:
    If i hold down S1 then S2 activaiting and after one click S1 and S2 turns both off.
    Parameter 28 key hold down and key released is activated.
    S1-id:312 and S2-id:313
    I have there singel switch which is connected only S1-lamp and S2 source is lamp. What i want to activate second lamp while holding switch (S1)
    Error for now is:[DEBUG] 13:21:15: 2018-12-13 13:21:15.459790 [ fatal] Unknown exception: /opt/fibaro/scenes/47.lua:15: unexpected symbol near '313'
    Thank you for the answer!
    I am sorry, I cannot write that scene right now, because I am on holiday...
    @Jarts495,
    I see line
    That 313 does not belong to that line, so please, delete that 313.
    Should be like this:
    Jakub
    @Jarts495 @Jarts495 @Jarts495
    3 hours ago, Jarts495 said:
    ok.
    Now i deleted 313. Scene starts but lights do not light up.
    DEBUG] 16:53:20: Scene started by clicking 'start' button
    Please try this:
    I've tried the code and my Double Switch 2 only works when I press once (but it recognises it as pressed twice) or held down (but it recognises it as pressed once)...
    Any one has had similar situation?
    I am trying to implement your script, @petergebruers , to use S2 on the double switch to control one channel on the RGBW dimmer. Where you write "replace with scene/.."etc, I have no problem with these commands:
    For "pressed" I use
    or
    depending on the state of the device. For "2 times" I use
    I simply ignore "3 times". But what about "held down"? The only relevant action parameter for the RGBW dimmer seems to be setValue. Does that mean that on "held down" I should start a separate scene, which uses setValue to increase the output incrementally in a continuous loop until max, and then decreases it (with a small time delay for each step)? For "released", in this case, I would just kill the "held down" scene. Or it there a smarter way? The dimmer, after all, has its own built-in dimming response in the firmware. It seems strange to have to mimic it in a separate scene.
    I haven't used this myself but I'd give it a try: "startlevelincrease" works on dimmer-like-devices
    Yes, I just found these two functions (startLevelIncrease and startLevelDecrease) by using 192.168.x.xx/api/devices?id=## and looking for actions on the RGBW dimmer unit. These failed to appear when I used the "HC2 Toolkit" program, right-clicking on the device and asking for actions. Here, only setValue, turnOn and turnOn appeared. Confusing! Thanks for clearing that up,@petergebruers . I will now start implementing these in my LUA scene, deciding first how to determine the dimmer direction (increase vs decrease). Initial thought: If the value is currently low (or off/0), I will increase; if it is high, I will decrease.
    Having tested extensively, I have now succeeded in controlling the RGBW dimmer as planned. The startLevelIncrease does not work with these dimmers, it seems, as reported previously a few years ago:
    In stead, I adapted a code suggested by @ReneNL in this thread:
    For my LED strips I chose a dim time of 2 seconds in 10 % intervals, which works well with a single channel on an RGBW dimmer controlled by the Double Switch S2.
    I attach my version of the scene, as it stands today (I may remove most fibaro:debug statements later):
    Set Parameter 20 on 0 (zero) = Momentary switch.
