Need help with LUA: 2 Motionsensors, one lamp
I have been using a LUA script for a while now for several scenes... It´s turning on the lights if motion is detected and it is night. Night is defined by a global variable which is set to night 45 minutes before sundown and set to day 45 minutes after sunrise.
This works fine, I have it running in the kitchen and in the foyer. A third scene is running on the stairs, but here I needed to add another motionsensor, since motion detection at the foot of the stairs didn´t work too good with the motion sensor located at the top of the stairs. Simple enough I thought...
But now the lights turn on during daytime as well as at night. Weirdly, this doesn´t happen after the first motion is detected. Instead the lights turn on after the motion sensors have detected motion several times.
I am hoping that someone can tell me why this is happening. Here is the script:
Edited by D4RK1
    maybe someone wants to achieve the same thing, so here´s the solution. In Line 29 additional brackets have to be added:
    Didn´t find out myself, a friendly user on another forum helped me out.
    Regards, Jens aka D4RK1
    Thanks for this, very useful
