Fibaro Flood sensor factory reset problem
Hi All,
I have a serious problem with my "flood sensor".  I have to do a factory reset on the sensor. I follow the maintenance guide and also see youtube videos, too. The red LED doesn't blink.
The HC2 hardware version is 4.503
What I did:
1. Pressed the TMP button and hold it
2. I waiting for the yellow LED
3. I release the TMP and after press it again so quickly after release
What happened:
The yellow LED blinks and after it was dark immediately . (The red LED doesn't blink.)
4. The sensor doesn't give a sings of life.
5. I removed the battery, after putting it back.
6. The sensor given a Bipp and after green LED is blinking.
Youtube link
15 hours ago, Reke said:
What I did:
I see you made it correct.
What happened:
If new battery does not help, you can try to reset it via Z-Wave through exclusion process or go with RMA to your reseller/dealer.
Hi all,
i"m facing the same problem like Reke and I sent back the devices to the dealer and I bought 2 new ones but the problem still the same...
I m using Homey as controler and I need this factory reset to be able to pair the flood sensor with it.
Thx
Edited by FH_GER
  • 4 months later...
I also have the same problem, what is the solution?
Reke, how did you solved your problem?
    He Hajallis,
    I try for all trick, but didn't work. I have to say to you, buy an another one... I was so angry about this situation, because the motion sensor had a same problem....
    • 3 months later...
    I am trying to reset the device after battery died.
    I follow the instructions but the light does not turn yellow and then green.
    It is always green and I can't pair the device anymore as it has been removed from the fibre app and the HomeKit app.
    Any suggestions?
    It works well on its own but I need a smart device not a normal flood sensor
    • 1 month later...
    I had this problem too...but I reset sensor via Fibaro home centrum 2
    And now is work it
    • 5 years later...
    Hi all - please note that the sensor should be connected to a power supply unit for decoupling, then this will also work without any problems. :-)
