nil value in VD
Here the simple VD code:
It is looped and working well but sometimes for some reason VD gets an error with a nil value for some variable (temp or pump).
Here on a screenshot
/monthly_2018_12/image.png.3853998ab5a91c1439cec774d03d351f.png" alt="image.png.3853998ab5a91c1439cec774d03d351f.png" />
Why the variable gets nil value?
How do I handle such error?
Thank you!
To avoid the error, and a check before the problem line executes.  E.g.
I don't know why it would happen.  Maybe a Z-wave comms issue.  What does the fibaro:getValue(tenpId, "value") return - i.e. before the tonumber function is called?  Maybe it returns a bad-text which the tonumber function cannot handle, and so returns nil.
