Remotec ZXT-120
I added Remotec ZXT-120 but it shows only heating as the picture. and the others empty. what should I do ?
thanks for helps.
Hi @malitan,
It also shows as non configured. Have you tried soft reconfiguration process?
regards,
Jakub
    hi @jakub.jezek,
    Yes, I did soft reconfiguration process.I couldnt understand why it is empty. I did everything.
    here is the pictures.
    ok @malitan,
    Now comes in mind, can you set parameter 27, to match manufacturer of your AC unit (again, maybe different code help) and hit soft-reconfiguration again? I think that could help in this case. Otherwise i think exclusion/inclusion could help.
