pablogiganti 0
I have the following devices installed in my bathroom:
Motion sensor “Toilet” ID 85
Motion sensor “Shower” ID 88
Relay 2 “Light” ID 77
Toggle switch connected to both S1 & S2
Fibaro HC2
Also, a variable to enable/disable all automations around the house. If “Automation” is 0, then the light should only operate manually.
Global Variable “Automation” ON = 1 | OFF = 0
This is how I´d like the bathroom light to behave as long as variable Automation = 1
1. STANDARD OPERATION
The light should turn ON and OFF when the light switch changes state
2. NO ONE INSIDE?
If no motion is detected by either sensor for 3min, the light should turn OFF.
3. OPS! THERE´S SOMEONE INSIDE
If motion is detected by either sensor within 1min after light was automatically turned OFF, the light should turn back ON and the 3min timer should restart.
4. LEAVING THE BATHROOM
If motion is detected by either sensor (on your way out) and the light switch changes state (you´r intentionally turning the light OFF), the light should go OFF (don´t do step 3)
5. FALSE POSITIVE
If motion is detected by either sensor after leaving the bathroom and switching the light OFF (false positive), the light should not turn automatically ON (which is what happens in point 3)
Thanks for your help!
