Woonveilig JSON and VD intergration [ SOLVED ]
Hello
Can somebody help me with a  JSON POST command ?
Simple Idea I need to press a VD button when there is a POST command made
-- 'mode': '0' = Disarm   should be like {'area': '1', 'mode': '0'}
-- 'mode': '1' = Full Arm schould be {'area': '1', 'mode': '1'}
I tried several thing but only get "  " to send in debug
And when I change the code to send ' '   the scripts fails
SOLVED:
seems that the github forum reactions and phyton code where misleading.
with httpPost:post and other raw data was the trick
Edited by D-Vine
Link to post
7 answers to this question
Hi!
here's how to do a POST from a VD:
Does that work for you?
Link to post
  • 2 hours ago, doezel said:
    Hi!
    Thanks for your reply.
    Works I hope
    accept the login I need to add user name and password...
    So after this I can test it
    How can I add it into this code?
    schould be like this if it's in one line
    Username:Password@192.168.178.134/action/panelCondPost
    Edited by D-Vine
    Link to post
    Hmmm, can't find how to add credentials quickly.
    But then I found this:
    this uses  Net.FHttp (for which you already now how to add credentials) and then describes to do a POST with a JSON string payload.
    Link to post
    Tried it but in VD already at first line got error in lua....
    think your code is best but now need to figure out how to get user and password in it...
    UPDATE:
    I just pust the userand password in front of the IP adress and the denied had gone...
    now can test the codes if they work
    This should be the payload
    When I run inspector got the area that is always 1
    mode 0 = Disarm
    mode 1 = Arm
    but no luck when sending got a TCP failed now
    Edited by D-Vine
    Link to post
  • I edit the first post...
    Just need a simple POST command hope somebody can help me with this
    Link to post
    Why are you encoding the jsonstring?
    try this:
    and tcpstring wasn't empty, you can read it like this:
    Link to post
    try this:
    solved with httpPost:POST command and area1&mode
    Edited by D-Vine
    Link to post
