Guest Turmoil
I have an FGS-223 switch unit in the garden with a permanent power line and lines from two physical switches in the house. Sometimes the FGS-223 does not respond to HC2 commands (both channels). When this happens I can toggle either physical switch and the FGS-223 starts accepting commands from the HC2 again.
All parameters are on their default values.
I saw on fibaro.nl talk about some type of wake-up polling being needed but the author was not clear (to me) what he intended. Is this a known problem? Is it likely my problem or is there something else?
Thanks in advance for any help offered.
