Alex Rob 15
i tried to do some settings for my motion sensors.
I set up 4 motion sensor with simular settings but i see that the react not at same time when u pass them, some are not triggered at all.
I mounted the sensor in the each room and they should be used as alarm and temperatur shall be used for main temperatur in each room.
I understand whats standing explained on each parameters but i like to know what adavced user can suggest for best settings.
I know that they are always active careless if they are armed or disarmed so i liked to sett upp blind time and reaction time to preserve battery as much possible but on the other hand they should not be too slow.
Im talking about paramteres 1 - 29.
I might be missing basics understandings i\m not quite sure.
The motion sensor wich controll lights works between 0 - 5 lux, it is a bit too low but i could not find a better place because it is placed under the roof outside out of range from car lights.
If i make a variabel is it possible to get it work to add 100 lux by paramter?
When sensor shows 5 lux then i like to programm it in a scene and add variable of 100 that it is 105 lux instead? /if someone is disturbing sensor with a light or something else it will not be triggered so easy.
