How to calibrate height of fibaro/somfy blinds
Hi there,
Im trying add somfy roller blinds + fibaro fgr-222 + Aeotec by Aeon Labs Z-Stick to Hassbian. I wired everything and the blinds go up and down.
However, it doesnt go down all the way, it stops somewhere 80% off the window bottom end.
So far i tried setting different parameters of fibaro fgr-222 including parameter 29 via hassbian's built in zwave configurator with no luck yet.
Wasted weeks already on this. I wonder if anyone faced similar issue before and could recommend any idea about fixing this please?? I dont have access to Somfy hubs, but open to other options, ie can i fix it using open zwave?
Appreciate any help,
Cheers,
Alex
Did you perform a calibration? you can do manual calibration on the fibaro devices by reading the manual.
