How to get JSON value if its name contains dots
Hi There,
i have imported a json table were i want to extract some data from.
normaly i would use  syntax like
local response, status, errorcode = ipadress:GET( ".............................'");
local Json = json.decode(response);
fibaro:debug (' The response is  ".. Json ..'' );
local parameter = (Json.name.value);
only in this case the name part of (Json.nam.e.value);  hase a dot in it name.
i get a error  [ERROR  malformed number near '.
Does someone know  the syntax  if you want to extract data if the name contains a dot?
Edited by fkruis
Look like
I am trying to define variable (skipped)
but when I trying to assign value (skipped) to my definded variable (skipped)
I get result (skipped)
my question is : please guess what was replaced by “(skipped)” text ;)
joke. If you wanna get result always provide full code and responses.
Sorry but forum magicmen now on vacation ;)
and last, in LUA you can access to object also as object[“name”]
    Hi 10der,
    i remove the information to avoid noise and to keep it general.
    it is working  now .  The syntax  should be  (Json["nam.e"].value).
    i had to remove the dot after Json .
    thanks for the help
