388hld 0
Hi all,
I have a UBS with a DS18B20 temp sensor on a HCL which is working fine on HCL version4.520
I also have a HC2 which has the above mentioned HCL as a remote gateway.
The system works fine, but every week or so the temperature fails to update on the HC2. The temperature is correct on the HCL
I have tried to "Synchronize Device'' on the HC2 without any success.
I have tried to "Synchronize" on the remote gateway in the HC2 without success
I have tried to "Import" on the remote gateway in the HC2 without success
The only success I have is by deleting the gateway and re-adding it, which requires reprogramming every scene in the HC2 which is related to the gateway.
Any help would be appreciated as it is extremely frusatrating
