  • 2
Alarm panel PIN code
Hi, I want to configure in the Alarm panel /Adavanced Tab the Fibaro Alarm configuration.  At one point the system is asking : Set the PIN code for Fibaro Alarm
I'm unable to enter a PIN there.  What's the purpose of this PIN and where can I set it ?
6 answers to this question
Hi
You enter the PIN when you turn the alarm on and when you turn off the alarm.
Hi !
What do you mean with "I'm unable to enter a PIN there." Do you mean you can see a four digit prompt but your keyboard entries are ignored ?
Sorry about hijacking the thread but I have another problem with the PIN...
I've set it up, I know what it is but it's not working to disarm my Fibaro motion sensors. Its not accepting my pin-code, wich I know I set up correctly.
What can I do? Remove/reset the motion sensors from my system and add them again, or what?
Edit: Dit not work to disarm with pin in the new "Home Center" app but worked fine in the old "Fibaro" app...
Edited by KoolaVippen
hello KoolaVippen
have  you sorted pin problem? i have similar situation. Cannot disarm thru iOS app. App does not accept pin code. Only way to disarm is to log in the website or iOS app offline login.
I have the same problem.
Has this been resolved as I'm having the same issue in the home centre app for android  but works fine on the old app
