  • 4
FGR-223 and percent position feed-back
Dear Support,
  I instal Fibaro FGR-223 new Roller Shutter 3 on my Domoticz system. I hd some painfull to add new xml OpenZWave but now is working well with all options. But I see a problem about percent opening status. Exemple :
  Roller is close at 7% and I ask to go level 50% ...that work more or less fine because
  1) Immediatly percent level gauge look 50% (instead 7%) on my Domoticz => Normal
  2) Roller move from position 7% to 50% => Normal
  3) But... percent level gauge on DOmoticz show again 7% (but roller is positionned on 50% like action was asked) => It's not normal !
  My suspicion it's than Fibaro device fgr-223 send after the starting move the old position only (and never new percent position level) ... it's possible ? How to solve it ?
I have exactly the same problem with my ZipaTile.
The RollerShutter 3 is updated to Fw 5.1, included an calibrated. So far everything fine.
When I move the Textile Screens with web UI or Smartphone App I get the new level shown in the App or on the screen.
But when I use the toggle switch the Screens move as long as the switch is activated (as they should do) but it takes up to 20 minutes !!!! until the new level is displayed in the App or in the web UI.
Is there any parameter to set the time for updating ?
Anybody else the same problem in a Zipato System?
Regards
Bernd
Regards
Bernd
I have the same problem in smartthings, did you manage to solve this?
Edited by VerhagenR
