Flood sensor ui ignores parameters
Guest minimax
Guest minimax
Hi @FIBARO,
I have problems setting parameters for FGFS-101. Every time I set for example parameter 9 to 1 (using template), it goes back to 0 after gui refresh. After waking up the sensor, the gui shows [11:27:42] ID 111: Received parameter 9 report, value = 1.  After refreshing gui again, parameter 9 stays at 0. So doing any other change and hitting the save button overwrites all parameters to old values. This is very frustrating. Please fix this bug.
Sensor FW 23.23
HC2 4.520
