Hello everyone !
I'm trying to connect a ZWav device on my smoke extractor (fireplace).
I choose a FGD 212.
Connection is ok, but regulation is not working :(
Currently the device is set to "not dimmable", and this settings is a read only.
I change some settings
- Parameter 16, from 1 to 30s because it's a motor, it need time to start properly.
- Parameter 34, 0,5 for long start filament (not sure if it's really useful for me)
- Parameter 39, power limit set to 320W
The parameter 33 is set to "no dimmable", and it's a read only value.
I made a calibration multiple time, without change on this value.
How to "force" the dimmable function ?
Because i just have the on/off functionnality, and i need a little bit more flexibility on settings.
Pretty sure I need to tune some settings to activate a manual mode, but i don't see witch one
[Edit]
This morning i tried to connect a light, to set an automatic detection (Param 13 : 1), and then set configuration to off (param 35 : 0).
Light was detected and variation was ok !
But replacement of lighting by the extractor was detected by the controller :rolleyes:
And calibration of power is not settable from interface, param 39 have a correct value.
I receive an alert, surge alert.
So it was not successful at all to try to hack the load ;D
Edited by RedVinchenzo
