Test471 0
Hi
I have door sensor 2 and it works fine (reporting temp and open/closed status) but every few minutes (5-10 don't know exactly) it starts flashing for no obvious reason (door closed and nobody it touching it). It is flasnihg first slow for about 8-10 times and then it starts flashing fast for another ~5 secs. I tried to reset both sensor and controller (using Aeotec stick with hassio) but it did not help. Also it is making this flashing when I open the door for first time after few minutes. If I open the door and close it several times in a row then there is no flashing but if door remains closed for several minutes and then I open it then it starts flashing.
Any idea what it might be?
