I put condition about running instances to script but it shows this error message again. Pls, see picture... Did I put it on the right place in the script? Thanks for any advice..
It shows this error message once for approx. 8-16 hours..
Mike
4 answers to this question
You did but it doesn't work that well. Increase the number of running instances at the scripts frontpage.
I have also this problem with a couple of scenes. I have a couple of weeks ago the number od running instances increased but this was not solving the problem.
I looking for a answer too.
The answer is to create a condition where only one instance can be run. That could be something with a change in a global variable instead of a device to secure that the device is not triggering scenes again and again.
I have a scene for my nodon wall switch and this wil only triggers bij the switch himself. But i get everytime to many instances.
