interesting light scene
I'm trying to create a scene with Graphic blocks but it doesn't work out the way I want it to be.
So I think I have to do this in LUA.
The idea is the following:
1 - when entering a room when light must turn on at 50% brightness, after sunset, for 2 minutes.
2 - after these 2 minutes the light has to dim to 10% brightness during 10 minutes and then go off if no one has entered the room in this time.
3 - when someone enters the room within these 10 minutes the cycle has to start over again, so go back to 1
Can this still be done with Graphic blocks and how can I do this? Of do I have to do it in LUA?
5 answers to this question
I think it is too advanced for block scenes but it rather easy in LUA.
Here is a lua program for turning on lights on movements and keeping it on for 50 sec unless there is movement. You can easely expand it with dimming function and longer period with lights.
I have a program in my hall that is in the lines with your ideas. It is just not connected with sunset but with time. It dimmes light in four steps with only 10 percent during the night.
4 hours ago, Thomasn said:
...Here is a lua program for turning on lights on movements and keeping it on for 50 sec unless there is movement...
Hi Thomasn,
I've have tried your LUA script, but when I manually turn on the light, it doesn't stay on, the light goes off after the 50 sec.
    Thank you @Thomasn
    I was missing the part of a period dimmed light and then turn off at no movement OR bighten up the light at new movement. Unfortunately it doesn't work, I seems I am missing something....
    Script ends immediately with debug: Light Off.
    ------------- Variables. Change to own values---------------------------------------------------
    local motion = 35-- ID for PIR
    local switch = 77 -- ID for Switch
    local starttimer = 10; -- Time for light to be on in seconds
    local timer = (starttimer); -- timer
    ------------- Do not edit program below this line -----------------------------------------------
    function debug(color, message)
        fibaro:debug(string.format('<%s style="color:%s;">%s</%s>', "span", color, message, "span"));
    -- Turn on / off light---------------------------------
    if ( tonumber(fibaro:getValue(motion, "value")) > 0  )
      then -- Movement!
      -- 2 minuten op 50%
              fibaro:call(switch, "setValue", "50");
            debug("green", "Light 50%")
            fibaro:sleep(5000);
            fibaro:call(switch, "setValue", "10");
            debug("green", "Light 10%")
    ------------------ Start loop ----------------------------------------
      repeat
      -- timer starts
        timer=timer-1;
            fibaro:sleep(1000);
             debug("grey", timer)
    -- if movement then restart timer------------------
           if (tonumber(fibaro:getValue(motion, "value"))) > 0 then
                timer=starttimer;
                debug("grey", "I see movement. Timer reset");
                fibaro:sleep(5000);
    until (timer<1)
    ---------------- Program terminates. Light off ----------------------
    fibaro:call(switch, "turnOff");
    debug("red", "Light off");
    5 hours ago, SmartHomeEddy said:
    Hi Thomasn,
    No, that is how I have designed the program. But you could add a line or two where a manually use of the switch will terminate the program. I would do it by setting a variable to 1 if the switch is used manually. Replace the scrip's manual control with this:
    If  (tonumber(fibaro:getValue(switch, "value")))  < 1 then
    fibaro:setGlobal("switchvariable", "1")
    fibaro:abort()
    and add a line in the beginning of the script like this:
    if (tonumber(fibaro:getGlobal("switchvariable"))=1) and (tonumber(fibaro:getValue(switch,"value"))) < 1 then fibaro:abort(); else fibaro:setGlobal("switchvariable","0"); end
    Remember to create the global variable switchvariable and that the pir-trigger first works again if the light is manually turned off
    NB: I have not tested the script!.
    Ok, this works for me - it is in Danish and the permanent on/off is not implemented:
    local motion = 264 -- ID for bevægelsessensor
    local motionToo = 277 -- ID for bevægelsessensor 2
    local switch = 51 -- ID for relækontakt
    local starttimer = 50 -- tid for tændt lys (ændres ikke af program)
    local timer = (starttimer); -- timer, der ændres i program
    local currenttime = os.date('*t'); -- Klokkeslet
    local currenthour = currenttime['hour']; -- Klokkeslet heltime
    -- TÆND OG SLUK LYS
    -- if (tonumber(fibaro:getValue(switch, "value")) < 1) then -- lys slukket?
    -- Hvis det er sen aften, så tænd med 20% styrke
    if (currenthour >= 22 ) then
    fibaro:call(switch, "setValue", "20");
    debug("grey", "20%");
    -- Hvis det er tidlig aften, så tænd med 40%
    elseif (currenthour >= 18) then
    fibaro:call(switch, "setValue", "40");
    debug("grey", "40%");
    -- Hvis det er sen eftermiddag, så tænd med 60%
    elseif (currenthour >= 16) then
    fibaro:call(switch, "setValue", "60");
    debug("grey", "60%");
    -- Hvis det er dag, så tænd med 80%
    elseif (currenthour >= 6) then
    fibaro:call(switch, "setValue", "80");
    debug("grey", "80%");
    -- Hvis det er midnat, så tænd med 3% styrke
    else
    fibaro:call(switch, "setValue", "3");
    debug("grey", "3%");
    debug("green", "Tænder lys");
    -- løkke startes
    repeat
    timer=timer-1;
    fibaro:sleep(1000);
    -- Genstarte tid, hvis der er bevægelse inden for forsinkelsen
    if (tonumber(fibaro:getValue(motionToo, "value")) > 0) or (tonumber(fibaro:getValue(motion, "value")) > 0) then
    timer=starttimer;
    debug("grey", "Nulstil tid, bevægelse erkendt");
    -- Slukker for lyset, når kontakt benyttes
    if (tonumber(fibaro:getValue(switch, "value"))) < 1 then
    debug("red", "Manuelt tryk observeret - løkke afbrydes");
    timer=0
    fibaro:sleep(7*1000);
    debug("green", timer);
    until (timer<1)
    -- Slukker for lys, når tiden er gået
    debug("red", "lys slukkes");
    Edited by Thomasn
    Hi, I got it working!
    I forgot to write the ID's between the --[[   ]]-- part
    There are still a lot of debugmessages, but that may be handy for someone else.
    %% autostart
    %% properties
    35 value
    37 value
    77 value
    %% weather
    %% events
    %% globals
    Dagdeel
    -- This program use a PIR to turn on light. If there is movement during this period
    -- the timer is reset. If the switch for the light is used manually the light will be
    -- turned off as it will when the program terminates.
    -- As standard the light is on for 50 seconds - but that can be changed in the
    -- variable section below.
    -- Made in Denmark by Thomas G. Nielsen 2017.
    -------- Do not start additional scenes ------------------
    if (fibaro:countScenes()>1) then fibaro:abort(); end
    local motion = 35 -- ID for PIR
    local lux = 37    -- ID for luxmeter
    local starttimer = 600; -- Time for light to be on in seconds
    debug("blue", "Start script")
    debug("orange" , "motion = ".. tonumber(fibaro:getValue(motion, "value")))
    debug("orange" , "lux = " .. tonumber(fibaro:getValue(lux, "value")))
    debug("orange" , "dagdeel = " .. fibaro:getGlobalValue("Dagdeel"))
    if (
       and  tonumber(fibaro:getValue(lux, "value")) <= 20
       and  fibaro:getGlobalValue("Dagdeel") == "Avond"
       and  tonumber(fibaro:getValue(switch, "value")) == 0
      then -- Movement!
      -- 2 minutes at 50%
            fibaro:sleep(120000);
      repeat
      -- timer starts
        timer=timer-1;
            fibaro:sleep(1000);
                timer=starttimer;
      until (timer<1)
    debug("blue","End script")
    Edited by Jackson
