Hello! Can anybody help, please?
I am looking for a way how to send a Modbus command - Preset Single Register to a Komfovent recuperation unit to change the function/Register number 5 (Current mode of ventilation) to 4 (Boost). Please see the attached Modbus communication codes from Komfovent.
I would like to use this command when the movement is registered in the toilet or other places.
Thanks a lot!
3 answers to this question
Hi.
Did you found a way to do this? I would like to install a heat recovery central ventilation, Komfovent or Wafe.
Hi, write [email protected] what you need exactly. Hc3 and modbus is doable quite fine.
Hi. Komfovent integration (via Modbus TCP) has just been published at Fibaro MarketPlace
