erikcramerjr 1
My Multisensor about 10 meters from my HC2 does not update its humidity status to the HC2 unless i press the Button on it.
Motion is updated Though, temperature lux etc is also not updated though.
I have removed and re inluded the device and gave it a soft reconfigure without result
its on firmware v 1.11
HC2 4.520
Param 40
is enables (Selectivly reporting when measurement reaches treshhold )
Param 41 Temperature treshold
1 Degrees
Param 42 Humidity Treshold
2 %
Param 43 Lux treshold
20 Lux
Param 45 UV Treshold
2
111
INterval of sending reports is group 1
5 minutes
Ive noticed though that the temperature treshold on both of my multisensors keeps jumping back to some insane high number
131097.6°C
Both different though, even though i changed it if i refresh the page this value jumps up again.
If i look in the logging feed i see this:
[19:21:19] ID 193: Set parameter 41, value = 10
[19:21:19] ID 193: Received parameter 41 report, value = 1310976
Edited by erikcramerjr5 answers to this question
