Power monitoring
in order to do power monitoring for Single Switch 2 do I need a Home Center Gateway or will it be available without it too?
Regards.
6 answers to this question
    To answer my own question the metering for HomeKit Single Switch FGBHS-213 is done through the Fibaro App. Only momentary consumption and total consumption since reset values are available, no charts, no graphs.
    Z-wave or Homekit version?
    For z-wave you need HC2 or other z-wave controller.
    Oh. I’m planning to use it for my HomeKit network but are they actually 2 different devices?
    Okay, so they are different. How the metering works with HomeKit? Thanks.
    With FGBHS-213 v1.0 you can measure the load power. But what is the power of the unit itself. The power of the Homekit FGBHS-213 v1.0 was measured with the Athom Homey-EU-02 domotica controller. I used the hand switch or the Homekit app to operate the switch. The internal power consumption of the FGBHS-213 v1.0:
         By using the hand switch:      lamp = on: 0,7W ; lamp = off: 0W.
         By using the app:                     lamp = on: 0,4W; lamp = off: 0W.
    This may be usefull information to find the loss of power in your home by the domotica itself.
    /monthly_2020_04/1239373969_InternalpowerFibarosingleswitchFGBHS-213.png.c463c2f456c8f0d58da531ba95ee2e1f.png" />
