Backup problem
Hi!
I just upgrade HC2 to version 4.53 and backup doesn't work anymore.. why? Not in cloud and not in local.
Strange is backup process will work great but it never came to the list
Yesterday version 4.520 works without problem. (in the cloud and local too)
Just good to know..
-Ville-
Finland, Kouvola
13 answers to this question
I have updated also to 4.53 and have made a backup and its woks fine. No problems here.
All ok after update but i follow notification to make backup... i try to make cloud backup and now, aftel 20minutes, my HC is stuck.... "stopping services" and nothing....
I have first 3 leds on (from the right to left) and 6 led (with + sign) blincking calm....
Any suggestion!?
Is stuck... with message "stopping services" in browser window...
Is safe to reboot now my HC?
Please, some help from Admin, I don't want to lose everything...
I wanted to upgrade HC2 to 4.53 and BEFORE upgrade I wanted to make cloud backup; result "please wait"
I try reboot
+recovery knoprecovery modus worked 5 minutes and restart; result "please wait"
Thank you,
Karl
On 2/5/2018 at 3:12 PM, I.Srodka said:
Hi @10der!
This error could be caused by two things:
1) a device was added with some errors
2) some device could wrongly report as a primary device/controller (some remotes did that in the past) while adding
I didn't add devices last 5 months;
all my +/- 150 devises worked properly
Hi, I just performed the update to 4.530 from 4.520 and it passed fine. Previous to the update, I performed the backup local and cloud from 4.520. I also, unmarked automatic backup from update start window. After the update, I performed one backup from 4.530 to the cloud as well as in local. It worked perfectly. I didn't notice any missfunctionement up to now. thanks
Thank you
then my problem will just remain mine,
Karl
After 60minutes with "stopping services" I made manual restart, HC leds starts and show like loading and after few time all leds gone... I thing this is the end, i lose all settings, devices, scenes
I made another restart and wait more time... HC back on again... everything ok.
No Backup in cloud. I'm afraid to make another backup, even localy...
Edited by rss
Had the same problem
restart HC2 and made first local backup. saw z-wave dump and backup was made
then made a cloud backup and it did!
Now i can upgrade firmware
BTW took me less then 3 min for backup
I had the same problem as Wille78. I had to reboot my HC 2 after 40 minutes of "Stopping services". I have version 4.531 beta.
After a restart I looked at Configuration --> Diagnostics --> Z-Wave and there was a message that one of my devices must me reconfigured. I removed the device as I do not use it any longer. After removing it I took a new backup and it worked perfectly.
Any suggestion!?
Hi @rss, have you solved the issue? I have exactly the same, although I was to make a local back up. Did you shutdown the HC2 or waited it out ? And what was the consequence if you restarted the HC2?
Thanks very much for sharing any result/advise
@HedzI shut down and wait 10minutes after this was back on and everything is ok.
Top thanks very much for fast reply
hello i have problem for hc2 backup and upgrade to new version ,why i cnt?
could you please help what shou i do thanks
Edited by zirtox.fibaro
  • -1
    Hi!
    I gave up yesterday. Today I looked HC view and ALL the backups had gone through as the original timestamp!? Backups work with 24h latency :)
    I tested little bit more and it seems to be a cache problem (not before). Different user can see newest backup.
