YR and Yahoo weather don't work
hello
trying to make a scene using the outside temperature
the real temperature is 6.5 degrees celcius according to my own weatherstation and 90% humidity
the YR website, reports 7 C
the yahoo website reports  7 C aswell, so both pretty accurate
when i use the yahoo plugin in my HC2 it says 0 C and 0% humidity !!
when i use the YR plugin it says 0 C  and 0% humidity
when i use the default YR it says 11 C 93% humidity
so both plugins are wrong,
my location is set to the right place in HC2
please fix this, so i can make scenes using outside temperature
using latest firmware 4.530
Edited by Klaasz
14 answers to this question
Hi, does your Google Maps work ok in your web interface location panel?
    i get the same message as you, but my GPS coordinates are correct
    i don't get that API error though, and i can use the map
    From what I have learned so far, the Google Maps are no longer free to use and you need to have your API key with billing directly from Google. I would advice to search this forum for more detailed information, though I didn´t have any luck finding something that would help solve the location and weather issues so far. :/
    Edited by paddovo
    i don't think the map is the problem, if i enter my city in the searchbox, it does come up with the right GPS coordinates, see below
    the map doesn't display, until i click it, but the coordinates are ok
    I have correct coordinates, but my weather is not updated neither in YR nor in Yahoo plugin. It stopped presenting data about 3 weeks ago. After HC2 firmware upgrade to 4.530 it is the same situation. Cannot setup my scenes using build-in plugins.
    Same problem here.. any info is is bug?
    I asked this from Fibaro support. They answered that they are aware of this issue and they currently working on resolving it as soon as possible :)
    I don't know...two months so far to fix a weather plugin. Wouldn't hold my breath as this seems very low priority for them
    YR isn't working since 2 or 3 month.
    Yahoo has stopped working since January 3 according to several sources (including Yahoo:/).
     Beta 4.531 seems to have fixed YR weather, have not tried it myself though.
    I can confirm it works now on my HC Lite with 4.531.
    Not working yet on HC2 Beta 4.531. YRWeather plugin shows correct data, but data is not transferred to other systems. E.g. display on the dashboard still stuck and when you read parameters from device "3" still the stuck values...
    Exactly my experience too. Fibaro has not solved the problem. They have just concealed the obvious flaws. I get "cloudy weather" regardless of the weather outside, when I read yr's data.
    Edited by Thomasn
    Here's an explanation from the
    about why YR Weather plugin is not working :
    //Gorm
