Since you say that app will become better based on our suggestions please note this, it’s about UI.
The way you defined rooms via drop down option it’s ugly and hard to access, in order to find my garage to open the door, I must scroll down...it’s not user friendly!!
I made a photoshop image like I see the rooms user interface, that it’s nice and clean, of course you can add section as well, and in each room you can add all devices and scenes associated, this will be more easy to access home.
  • Like 4
Guest Liam17
I agree, its not very efficient the drop down, your suggestion looks a better way of doing it - with more information aswell.
    @FIBARO take a look...
    I have seen many complaints on this forum, and you say @FIBARO taktake a look???
    I haven't seen any reaction from Fibaro in the android or Apple section.
    I hope that there will be very quickly a update otherwise i think that there will nobody use this app anymore because it's not useable. Many things don't work and every ware you co in the app you must scroll scroll scroll and scroll.
    YES, i don't like scrolling also.... What i suggest for rooms looks awesome and also like @Liam17 said, show all info that you need.
    Will be great if in one room we have all all devices, VD, and scenes + section for lights, switch...so on like @FIBARO do.
    The Photoshop mashup is exactly the way it should be! Fibaro, please take note. The new app looks great (and the new app icon is nice) but there is just not enough information on a single page, everything is dragged out and space is wasted. We need compact and efficient layout, not layers and layers of menus. This is one of the use cases when cramming as much as possible into a single screen is actually a good thing. When I launch the new app, I see almost nothing, everything I want to do is hidden away. :(
    Yessss...great idea @MDC...like in the old app...scrolling down my over 20 rooms to switch on a light in the new app is not smart.
    The main page must be editable - there's no need that the app defines what is important...I will do this on my own!
    Forst of all: the new app is a good start for renewal.
    Add-on to the above:
    Please look at iPhone fontsize dependencies. I have a rather big fontsize in my phone iOS in order to be able to see without glasses.
    The app appearance currently looks strange with font overlap, only small parts of object denominations visible etc.
    I understand that not all fontsizes might / shall be supported - so even if it would be inconvenient for me (and evtl. others) I propose to disable variable fonts if not programmed well in the app.
    • 4 weeks later...
    " to "
    Temat został przeniesiony z "
    " do "
    " to "
    " do "
    ...and here will stay forever!
