Borgstrand 3
So in the setting under Parameter 40 I have it set to "3 - flash after receiving the alarm frame".
But how is this triggered?
I did assume that "General Alarm" would be the same as a motion or door sensor being triggered. But apparently not as nothing happens when I test to breach an armed sensor.
So how do I trigger this so that the switch start to "flash".
I assume that this "flashing" is done in the device itself and not through receiving on/off commends from the HC2? Using the "emergency light" in Fibaro Alarm quickly becomes useless if you want 3-4 (or more) devices to flash in case of a breached alarm as it overloads the HC2/ZWave network with on/off commands and the HC2 becomes slow in responses.
