vic_mar 0
I am new to this forum and I looked around, but could not find the information I need.
I plan to install a living room decorative light with the following:
4 x RGBW LED Strip (RGB+NW) 24V-14.4W/m- IP65-CRI80-12mm/2oz PCB-5m Roll
1 x LED Driver 400W 24V IP67 Premium Series
1 x FIBARO RGBW Controller
Total length of the LED strip will be 17,5 meters. I want to use the strip with dimmable natural light most of the time. Also I want to be able to make different static and dynamic set ups, that I may save and load. For example, I would like to set up each separate strip to change between different colors smoothly. I do not have a smart home controller and do not want one, as I would use it only for this particular light and it would be an expensive solution.
Is there any way to configure the RGBW controller without a smart home controller? I need a simple and cheaper solution just for this one RGBW controller and nothing else.
Thanks!
