Danielos 3
Dear all,
I'm using the normal "Sonos Speaker" Plugin from the Fibaro Marketplace. I'm struggeling with a simple LUA script to simulate a push "resume" / "play" button on a specified sonos speaker. Can someone help me, how I can realize that? I just want a script to unpause the music, not more..
Thank you very much for your help.
Dan
13
3
2
Jan 12
10
Jan 14
4
Jan 19
3
Jan 16
3
Danielos 15 posts
Krikroff 13 posts
kevin 3 posts
Vadim Krasnoslobodtsev 2 posts
Jan 12 2019
Jan 14 2019
Jan 19 2019
Jan 16 2019
Krikroff
Hi @Danielos, seems to me an old or corrupted version. Please try with the following: 1. Remove your SONOS Remote VD from your HC2 2. Go to http://YOUR_IP/fibaro/en/panel
Krikroff
What is the version you use ? To virtually push play buton the correct way is Please login or register to see this code. Please try with this code
Krikroff
@Danielos, could you send me your VD for further investigation please ? Regards,
41 answers to this question
