markp 0
I'm having some strange issues with Fibaro Relays on my HCL's
My setup - 2 x HC2's 4 x HCL controlling lots of stuff around my house (around 80 devices mostly Fibaro) with the HCL's in other buildings around my section where I get poor Z-Wave coverage. the HCL's are setup as gateway connections and all human interaction is done via the main HC2. I'm also using a HC to control a Victron Energy switch with battery banks, generator, and electricity exporting functions. also I'm running the latest beta 4.530
My issue is that many Fibaro Relays connected to the HCL's recently have refused to turn off, this does not appear to be the "sticky relay problem" as if I do a complete re-configuration of the device it works fine again. I'm also noticing that this is way more apparent on devices that I set as sprinklers where it will instantly turn on, but the off command fails to work (although Fibaro does show that communication was successful) and either the relay will not turn off, or on occasion it might turn off up to an hour later.
There don't seem to be any signal issues, and this is only happening with the HCL and not the HC2. a soft reconfiguration does not help, neither does reapplying the mesh configuration - I actually need to remove the device and re-add, and it works fine for only a day or so.
Any advice greatly appreciated!
