Problem using json.encode and json.decode in a VD
I have a problem, in a VD when I try to encode an array variable, I have an error during the second encoding while the first works well
Here is my code:
I get the following result:
The error occurs as soon as I set the second encoding after an encoding function.
It's been hours that I research the cause and I can not find. Do you have any idea of where this problem comes from and the solution?
Here is my code:
...because you redefine the 'json' variable here
    Another person had also given me the solution. Thank you
