Sonos control with keyfob
Hi. I would like to Control my sonos amp and Connect through a keyfob. Only play/pause, toggle between favourite radio stations and volume Control. I've found a couple of VD's controlling sonos but either it don't work or the VD have a volume slider, two buttons for play and pause and one button for each favourite station… I'm not good With lua. Thanks in advance!
Edited by kje
11 answers to this question
Guest vipernor
+1 sonos volume buttons
Goodmorning @kje and @vipernor. What VD -do you use to control your Sonos?
I have a VD scene combination (work in progress and very crude) that does just that.
But I use @AutoFrank's API solution.
Anyway I've attached the VD and scene so you can have an idea how I do this. The scene gets the key presses and presses a button on the VD.
Jim
Files:
Guest vipernor
Good evening @jimicr. Thank you for the heads up. I use @Krikroff sonos VD with the volume slider, but I havn’t solved the keyfob volume or  button press part yet. I have a rpi for Homebridge, MagicMirror and the Kodi/Plex fibaro plugin by @Shad and ADN182. I was kind of hoping to avoid more rpi’s, but I have an old rpi laying around that might do the trick.
Edited by vipernor
Here is scene that can be used with Fibaro KeyFob to control @Krikroff sonos VD:
How keys are used:
  • Pressed ONCE
    • Key 1 - Stop playing
    • Key 2 - Start playing
    • Key 3 - Toggle mute
    • Key 4 - start playing favorite station No 4
    • Key 5 - volume down for 5%
    • Key 6 - volume up for 5%
  • Pressed TWICE
    • Key 1 - not used
    • Key 2 - not used
    • Key 3 - start playing favorite station No 1
    • Key 4 - start playing favorite station No 2
    • Key 5 - start playing favorite station No 3
    • Key 6 - start playing favorite station No 4
You can freely change scene to suit your needs!
Enjoy coding :-)
Where can I download the Krikroff Sonos VD? I don't find it in the download sections?
Guest vipernor
Holy crap! At this moment I'm crying happy tears. Thank you @Sankotronic! Best morning ever..and I was so close.. and yet so far on my lua script..
Always happy to help! :-)
No 1 ? :huh:
Guest vipernor
@Sjekke
On 1/2/2017 at 9:42 PM, Sankotronic said:
You can download from French Fibaro forum here:
but first you need to make account and leave one post here:
thx @Bodyart and @vipernor
You indeed had to leave a message before you can download something.
Have a nice Sunday!
