Simple scene to control light in a storage room
This is a simple scene I have put together to control light in a storage room that has "Door sensor" and "Motion sensor" and to have the entire control in one scene.
The scene controls lights when door is open and closed and also uses motion to turn off light if no movement for a period of time (TIMER) and turn on again if movement is detected.
You only need to change:
1. Put the number of your door and motion sensor (100 & 200 in this example) under %% properties
2. Under "Settings" change to your door and motion sensor numbers (100 & 200 in this example) and change to your light switch number (300 in this example)
3. Under "Settings" change to the number of second you want the light to be on when no motion is detected (240 in this example)
Any one more experienced LUA coder have any good suggestions how I should optimise the code or any other good input/suggestions?
