Hello Fibaro community,
just wanted to present a idea might be intreseting for Fibaro?
All Fibaro Devices / Products are really good and if i take the PIR Sensor as an exampel its the leading sensor on the market.
Could Fibaro produce a weather station with battery powering just in case if there is not enough sun?
Make a weather station solar driven with battery backup and such big cappacity that it could survice on power even by bad weather conditons about several weeks?
That would be great, i try to charge the popp z weather but still after 2 weeks no succedd of using this product. Might has something to do that im located above polar circle not sure.
  • 5 weeks later...
" to "
Temat został przeniesiony z "
" do "
@Alex Rob , I must say that this is a great idea!
I cannot promise anything but if the market and our community shows such a demand then it is possible that something like this will be created by FIBARO ;)
+1 for weather station.
hi @Alex Rob,
forget about the Popp Z weather... it's a bad joke.
Why not use this one, as it's basically what you describe:
BR - kro
    It looks good but I rather hope Fibaro is creating a weather station I see that Fibaro products are better and have more functions than any other z wave device.
    • 4 weeks later...
    Guest Bastian
    +1 for the weather Station!
    Yes a good weather Station from fibaro and /or with Z-Wave will be great!
    I have the Netatmo: nice but the wind sensor is not usable for "wind alarm" scenes.
    Testen also the Qubino Station but i Bad a hole lot of problems with the connection from the Sensors to the Z-Wave stick. And also the Qubino station is not produced anymore and you will find hardly one in online shops!).
    There is no good weather Station for Z-Wave in the European market.
    A real lack!
