Macschimmi 35
Could I give you a tip, I have a problem with the Fibaro Intercom.
After I set this up for the first time, only went via Wi-Fi? why ever, I could then connect via LAN via DHCP.
When I tried to give the intercom a fixed IP via the app, it was not possible to get on it.
So I did a reset on the hardware.
Now I'm no longer a connection via LAN only WLAN Is there a trick?
How can I delete the old data from the cloud from the intercom?
Maybe you have an idea
Thanks for Help
Michael
Edited by Macschimmi2 answers to this question
