I don't know if this is the right section to ask it, but I didn't found a section that was suitable to do this question. I'm new with Fibaro and I'm starting to learn how to do scenes with blocks. However I want to explore more, and for that is clear that I will need to start programming using code. I searched and foud out that Fibaro uses LUA programming language.  I learn C++ a few years ago, and I would like to learn LUA programming, so that I can explore the fibaro system to the max. What book do you recomend me to read? Any sugestions?
You can try the next link.
Maybe someone else have a better idea but i reading this site to try understand lua.
@Bruno Azevedo
Don't know if it is a good idea, but I  am creating block scenes and convert them to LUA and trying to learn from that.
May be awkward way, but works for me
Edited by AR27690
    Thank you both, it is a good start :)
