Martin-Fibaro 1
I have 3 FGT-001's, running firmware 4.0.
I think from 2 of them the pin button is broken.
Both devices are 'awake', and respond to manual setting the temp (ring lights up and indicates temp color).
Adding them to the network didn't work, never saw the blinking white LED ring.
Trying again, or trying to get to the color-ring menu has no effect.
I can press the button (with the pin key) as long as I like (several minutes), noting happens on these two devices..
The third FGT-001 works very well. I was able to add it to the network.
The devices was updated to firmware 4.4 using HC-Lite.
Í could put the device to back to sleep (cyan) using the pin button. And add it to the network again etc.
So the pin button handling is ok on the third FGT-001.
Not sure what to try next..
If I remove two from their valves, in order to return them to the shop, they will start calibrating every 10 minutes.
Not sure if that's a solid idea for a package in the postal services that's producing a buzz every now and than..
Any idea's?
I'm willing to take one entire knob apart, but will need the proper disassembly instructions.
Many thanks,
Martin
4 answers to this question
