Guest Turmoil
I have an HC2 running 4.530 with a number of users defined via the Access Control panel. My fibaro ID use has the admin account owning the HC2 with two other accounts granted user access, these accounts match local definitions. When connecting remotely I am no longer able to log in directly from home.fibaro (fibaro id), instead I see the local login panel which allows second login.
My questions:
1. HC2 user definition allows for a login name and email, if these two differ I can only login locally with the login name. What is the purpose of login?
2. HC2 Access Control, what is the purpose of the synchronize button?
3. How is login supposed to work? I'm guessing each HC2 contacts home.fibaro but how is this getting past NAT? Are all remote connections trunked via an HC2 to home.fibaro connection?
4. I have tried the forum for this information without success but it would be really nice to for once see some supplier documentation that indicates how it is intended to work. Has anyone seen any?
5. Has anyone experienced my problem "I am no longer able to log in directly from home.fibaro (fibaro id), instead I see the local login panel which allows second login"? I think its preventing my Google Assistant from connecting properly.
Thanks for any help anyone can provide.
4 answers to this question
