what is the difference between Automatic and manual scenes
Hello All,
What is the difference between Manual and Automatic scenes please?
if the scene is set to manual, does that mean that triggers will not run the scene?
for Automatic scenes i can always an instant running although i put a trigger to start it at a certain time, is that normal?
i have few scenes that should run at a specific time and change the colour light depending on the temperature, however, since they are set to Automatic, i can see running instant all the time, and the lights are changing all the time depends on the temperature not at the specific time in specified?!
additional question, I created several LUA scenes but none are running with the specified triggers... do i need to add anything in the scene to make the trigger work?
Many thanks,
PS: if you looking "%% autostart" directive - its just sign for HC2 start immediately after boot or after scene save action
