Configuration of RGBW Controller
I’m having trouble configuring or adjusting the FIBARO System FGRGBWM441 RGBW Controller and its RGBW Led strip. The led strip has 4 leds (Red, Green, Blue, White).
But I dont know how to adjust it to get the colour I want, if I switch it on via the main switch (next to the name) it turns on all the leds, when I turn on one colour it shows that specific colour. But I cant mix it, the colurwheel is not working.
I have set the parameters of the Controller to following
1 = ALL ON active/ ALL OFF active
6 = Normal(RGBW) - COLOR_CONTROL_SET
8 = MODE 2 - Constant Time (RGB/RGBW only…)
11 = 67
14 = 8738 (momentary, normal mode)
Rest of the parameters has the default values.
I have one momentary switch connected to input 1 that I would like to control all the colors and the brightness of the led strip.
Can you tell me if I have configure anything wrong ?
BR,
Fredrik
Edited by dubbfredda
I'm not sure if the color picker works with Home Assistant.
I noticed this topic on their support forum.
