Netatmo welcome -> stop surveillance
Dear all,
If someone comes home, I'm using the "person is at home" function with fibaro. But I'd like to stop surveillance as soon as someone is at home. Is there an option for that? In the netatmo app, you can stop the surveillance but I can't see an option with the API.
Thank you for your help.
Dani
8 answers to this question
Yes, it is possible. I switch on the Netatmo Welcome only if my alarm system is on.
via the following call. Works very good.
BR,
oliver
    @obendig that sounds great, thank you for the hint. Could you please send me the whole LUA script you us for that?
    I mean it should be like that, isn't it?
    Thank you!
    Dan
    Here is the Script that I'm using. I have changed an exisiting script from someone else to me needs.
    I'm using the a Global Variable with the Name "NetatmoPower" as a Trigger. My Alarm Scene puts it NetatmoPower = 1 to switch on the Netatmo and 0 to switch off.
    Appologies for the German comments in the code. :-)
    You need to add your credentials and API information in the oAuth Function section.
    local client_id = 'YOURID'
    local client_secret = 'YOUR-CLIENT-SECRET'
    local username = 'YOUR USERNAME'
    local password = 'YOUR PASSWORD'
    @obendig that works perfect, thank you very much! And because I'm also German speaking, it's absolutely no issue. :-) Thanks again!
    Edited by Danielos
    @obendig Oh, still a little problem. I created 2 scenes to switch the status. First script:
    Second Script:
    The idea is to set the variable to 0 or 1 and afterwards, start your scene you posted. Strange is, that it works sometimes perfect and very often, the Variable "NetatmoPower" isn't changed and so nothing happened. :-(
    What could that be? Or do you have a better / more reliable way to manage that?
    Dan
    If I look at your trigger scene, I guess you trigger the scene multiple times.
    If you create a trigger scene that changes the variable Netatmo Power to 1 or 0, then you do not need to have the variable as trigger for the trigger scene :-)
    And you don't need to start the scene from your trigger scene via fibaro:startScene, if you keep my original scene. It gets automatically started by variable change of NetatmoPower. The change of the variable is the trigger of my scene.
    The following should work if you want to add a trigger scene that you start manually.
    @obendig: That works brillant, thanks!!!
    Hi
    I'm a new user on HC2.
    I want to integrate my welcome cam. I created a new scene from your script on my HC2.
    Alsa I created a a global variable with 2 values (0 and 1).
    But on debug I receive always:
    Kamera Status: off
    Netatmo Welcome wird angeschaltet
    Variable steht nicht auf ON, deshalb wird Kammera nicht angeschaltet
    Were I wrong?
