Streams from Fibaro Intercom
I'm trying to install Fibaro Intercom at my home.
I create Fibaro Account, Install Fibaro Intecom App from AppleStore, connect to Fibero Intecom and received call from it.
The picture is horrible, very slow, interrupted... (see video below)
I try to connect from Wi-fi LAn and WAN. but the result is the same.
Help me...
P.S. I see History log, but I can't view videos...
18 answers to this question
The result is the same as mine, even in settings on the worst resolution results in a clean, smooth image.
Fibaro Intercom is expensive toy, not mature and has errors without end.
I can not get it connected to LAN or WLAN anymore.
Now it has to be sent in, test it after 1 week - well that I have not yet bored a hole in the wall.
    @Tony270570 All other cameras which working in my network, works perfectly inside/outside my network (LAN or WAN). And sure I had connect my Fibaro intercom with POE. Everything that I try is useless. Even when I calling to support there is no answer...((( My network is clean because I create it exclusively for this Fibero intercom(((
    @Ustya if you go into the configuration menu (upper right icon) what kind of connection do you see, remote or local? I've got exactly the same issue as you I mean jerky image, if i'm connected on remote (3g or 4g) where the connection is bad.
    Could you please have a look?
    always remote, and I didn't know how to switch to local...
    Well you've found where the issue is ;) is your phone connected to your WLAN ? the application should automaticaly switch between local if your phone is on your WLAN and to remote when  your phone is not connect to your WLAN.
    Hm... I now connected to Wi-Fi in my network and application didn't switch between local or remote... it is always remote((
    try to exit from the app and relaunch it and check.
    i done this, and even reboot phone - The same thing - still connected as remote through my WLAN...
    not sure about this one, but did you set the local(hc2 pass) password under USER Settings?
    Are you saying that the local password should be the same as the local HC2 password?
    Hello, no I was just asking if the hc2 pass has been filed on the app. Are you also connected remotely to the interphone when your phone is connect to your WLAN?
    Indeed, I can only connect remotely. The Intercom is connected via LAN to the home network. The WLAN is connected to that same network.
    Ok i'll install a new phone and check if I can reproduce. I'll let you know.
    hi @middelweerd, I've reinstall from scratch the app on my mobile and resetup it. I've only entered my fibaro account, and then the app is able to connect locally without any problem.
    Try to remove and re-setup it again. Sorry to tell you that, but make sure you are entering your correct fibaro id address. I'm telling you that because I did the test entering a wrong one and the app just asks to enter a password twice and i assume create an account. I didn't went until the end of the test and don't know how the app behaves, it maybe just able to connect remotely.
    keep informed ;)
    Edited by Tony270570
    keep informed ;)
    Thanks @Tony270570,
    I've entered the correct ID. However I've tried the above and I still can't connect locally.
    hi @middelweerd, Ok strange,  could you please switch off your 3G/4G on your mobile and make sure your are just connect to your wlan and check what kind of connection you have?
    Are you on IOs or Android?
    Last thing, In the plugging under the HC, you have a local configuration section, please make sure you have entered the local credentials.
    I'm on iOS.
    Changing to WLAN doesn't make a change. Always connected remotely.
    The local credentials are filled in in the plug-in.
    • -1
    Hi guys, I must admit that i didnt try playing with  WIFI configuration, I prefer wire connection when possible, I had 3 others brands before the fibaro intercom, and including same price range devices,  I can inssure you that this intercom is working really well, all people I know having it,  doesn't have any issues, could be intersting to contact the support, i'm sure they will be able to help. They are many steps of investigation before to declare that something doesn't work.
    @Ustyado you have another camera at home? could be interesting to make a test and check the image is not jerky, looks like your network is saturated. Another thing you need to check is your phone really connect to the wan or are you in 3/4g?  I try to have a look to your phone but it's to small. If your in 4g it might explain some lags.
